- Joined
- 13 Dec 2007
- Messages
- 4,009
- Reaction score
- 661
- Country
Suki, what you propose is called a thermal store, I fitted one last week. It is fed by a log burner and an oil burner and feeds DHW, central heating and swimming pool..
But But why do you want to dump heat at 80 to the heating.
What you are talking about is a thermal store and it's nothing new.
My wind up spidey senses are tingling.
sounds a bit like a school project with the homework being done by others
teapot.
cold.
boiling water poured into it.
Damage? Nil.
Do it dozens of times a day.
Well! Please correct me if i'm wrong but from what I understand is that most boilers pump water at about 80 or 82 degrees and there is a loss of 10 degrees throughout the heating cycle. but that 80 degrees is quite slow.
It used to be 82degC (180 degF) flow 71 (160 degF) degC return; now it's usually 70 degC F, 50 degC R.
I can't see any reason why you'd want to circulate water at 80 degC.
It wouldn't damage a radiator.
If you had the heating flowing continuously during the hours of occupation, and regulated the room temperature by modulating the flow temperature, there's no clicking or creaking, except on start-up. Most heating systems creak when the thermostat closes and the heating starts circulating (pump starts, zone valve opens, etc..).
do you mean you are asking these questions because you have an interest in making claims for a heating system you hope to sell?
How do you intend to heat the water that you intend to pump round the radiators, and how long do you think it will take for your thermal store to become hot?
It is not true that a cold room with a hot radiator in it, suddenly becomes a warm room.
I believe if i put really hot ware through the rad .I will heat up the room quickly( almost instantly)
I believe If i start selling a product with an "instant space heating" feature. People would buy it.
I havent calculated anything in this case. In real life that may take longer but still it'd be quicker than any other boiler.
Please let me know what you think.
Kind Regards
Surely the rads are going to contain cold water to start with so there will never be a 'sudden' influx of hot water as there will inevitably be a mixing of hot and cold as the circulation starts up. I can't see how you can suddenly dump hot water into the rads. They can't be empty as this would just create a massive airlock.
Unless I'm missing something blindingly obvious?
I think there's so many disadvantages to your idea that it would it would take months to list them all.
It appears (to you) to be a good idea, but you do not have the specialist knowledge or experience to anticipate the many disadvantages.
Look up 'mean radiant temperature', for a start. You'd bring the air temperature (but not the MRT) up to the setpoint much quicker with a convector heater. Or reach the MRt (but not the air temperature setpoint) with a radiant heater.
I once thought it might be a good idea to circulate chilled water through a heating system to provide cooling in summer. With the benefit of some years experience, I know you could, BUT................................
It is a big 'BUT', in both cases.
