Hoover HDV7 Tumble Drier - not drying any more
23 Jan 2008
Glasgow
Hi - as the title says, our HDV7 has stopped drying clothes. It seems to tumble fine, timer OK etc..
For a while, there was an intermittent fault where it sometimes would sometimes wouldn't dry the clothes.
It now seems to just not!!
Any ideas for a fix
Thanks in advance
I've tried to get as much of the fluff out from both the back (where the pipe connects to) and just inside the door, where there is a plastic gauze basket type collector.
Is there likely to be a blockage somewhere - I'm happy to take it apart to get into the guts, but didn't want to if there was a likely problem in terms of a faulty part etc...
Is this more likely that a faulty heating element, or potentially thermostat, which I would assume controls the level of heat output from the element.
Also, is there a simple way to check the element etc... before going to the hassle of changing parts. (assuming it's not simply a blockage)
Thanks for the advice so far
IF its hot the heater works..but if its blocked with fluff it wont work
