Hoover Performa 1300 - Unable to drain
16 Dec 2004
Dear All,
I am having a few probs with my hoover washing machine, as it does not drain the water. I have checked for various blockages in the hoses (from drum to pump, pump to drain) and a wire was found, but did not rectify the problem once assembled. The washing machine fills with water and spins around but no water is drained. Is there a filter with this particular model and if so could someone please indicate where this is located and how l should clean it?
Any thoughts of resolving the problem would be gratefully received,
many thanks
Charlie
seeing as you know where the pump is could you not fllow the pipes and see if there is a filter?
thanks for your reply,
l could try and see where it is located, however, what does the filter look like?
the impellor was obstructed by a wire, works now, thanks for your help!!
cheers
