Hi
I have 2 problems with washing machine. First problem is I cannot use the 90 degree hot wash, it momentarily starts then does nothing and stops. Secondly it fills and empties but does not tumble or spin. Repair man came today and said he fixed the first problem but I have tried again and he hasn't and secondly he says that I need a new circuit board costing £174.00. Can this be really true as the machine is less than 3 years old. He says brushes are OK. Expensive machine at £459 for less than 3 years use. The second problem has only recently happened so presumably they are not both connected but do you think this one part should cure both problems?
