My customer has a system boiler and unvented 170litre (upright) cylinder in their loft. Adding an extension to the house, including a bathroom, they want to increase the cylinder capacity (I don't think there are any additional occupants being added, but they want to 'future-proof'). They'll also upgrade the boiler.
Loft hatch is 60cm x 60cm, so will take up to a 55cm dia cylinder (same as existing) as long as there are no welded feet/stands/other protrusions which add to that diameter (naturally fittings will be added in situ). Vertical installation space is limited, so I am considering a horizontal cylinder (I've seen a Gledhill one, maybe others?) up to 250litres, which will be 175cm in length. Note: I believe(!) there is sufficient room to insert a 175cm long cylinder into the loft (but not to install that height in the required location)...I will do a little more verification on this, though. I'm keen to continue to use the loft space, given that all the plumbing is already there, and it's a good use of the space.
I've not fitted a horizontal cylinder before, and haven't really heard anything about them. So, I'd like to canvass opinion here, ideally from your practical experiences...pros and cons, warnings, etc, including whether Gledhill is OK (my experience is limited to Megaflos).
Much obliged.
Much obliged.
