Horstmann 425 diadem to hive
11 Nov 2026
Trying to convert from a Horstmann 425 diadem to a hive system. Although the wiring is completely baffling me. Any help greatly appreciated.
As said yours seems to be connected DHW only 1794474662331.png so not sure if you should use terminal 3 or 4, I will have a guess running some sort of C Plan? What motorised valves do you have if any, the C Plan normally no motorised valves, and it runs just boiler for DHW and boiler and pump for CH, the Hive has a software fix, so it is one of the few that can work C Plan, Wiser does not have the software fix.
As said yours seems to be connected DHW only View attachment 426382 so not sure if you should use terminal 3 or 4, I will have a guess running some sort of C Plan? What motorised valves do you have if any, the C Plan normally no motorised valves, and it runs just boiler for DHW and boiler and pump for CH, the Hive has a software fix, so it is one of the few that can work C Plan, Wiser does not have the software fix.
Took some more photos of the setup if that helps.
