    Dismiss Notice
Horstmann Electronic 7
Discussion in 'Electrics UK' started by SE5Will, 6 Feb 2017.
  1. SE5Will
    SE5Will
    6 Feb 2017
    2
    Thanks Received:
    Country:
    Can anyone help me with this? I rent, and I'm on day/ night rate electricity with edf. Now shamefully I noticed sometime ago that there has never been any display or life coming from my hot water control panel, a horstmann Electronic 7 series 2, as below
    [​IMG]
    Since I had hot water I didn't really worry about it until now. So I isolated it, opened it up and had a look...
    [​IMG]
    So what appears to have been done is the 'Live in' (which should be in connection 1 on far right) and the 'live out to immersion' (connection 5 on the left) have been connected to bypass the controller.
    So it seems my hot water is constantly being kept hot by the lower element whenever the thermostat calls for heat, which I imagine is costing me a lot more than it needs to.
    Firstly, for what reason might somebody do this? Secondly, were it all to be reconnected as it is supposed to be, would it be likely to work? It has likely been disconnected for a few years. The water tank has two elements and seems in good order.
    Any help very much appreciated!!
  2. jj4091
    jj4091
    1 Dec 2006
    5,157
    Thanks Received:
    482
    Cumbria
    Country:
  3. Sponsored Links
  4. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,553
    Thanks Received:
    2,132
    Oxfordshire
    Country:
    It looks like the Horstmann has died (they do that sometimes)and someone has bypassed the off-peak connection.
    As you surmise, it looks like you are not getting any off peak benefit fit the DHW.
    Your landlord should be required to fix this, properly.
  5. SE5Will
    SE5Will
    6 Feb 2017
    2
    Thanks Received:
    Country:
    Thank you for the advice.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
