    Dismiss Notice
economy 7 horstmann E7 tripping
Discussion in 'Electrics UK' started by sijaysee, 13 May 2011.
  1. sijaysee
    sijaysee
    8 Dec 2005
    344
    Thanks Received:
    Cornwall
    Country:
    got a new twin immersion unvented direct cylinder and customer wants to use economy 7 for heating through the night on the bottom immersion and another circuit for boost as needed on the top immersion. got a horstmann electronic 7 programmer and connected up but it keeps tripping the rcd when the boost switch fused spur is turned on. the E7 and the normal heating circuit come from 2 seperate CU's and are both on rcds and then go to their own switch fused spurs and then into into the horstmann 7. the lives from the fused spur both go into one terminal on the horstmann and it seems that its sending current down the switched off economy 7 circuit and tripping. the manual says that it is compatible with economy 7 but not sure how this setup would work? any ideas?
    cheers Si
  2. Sponsored Links
  3. flameport
    flameport
    10 Mar 2007
    9,026
    Thanks Received:
    1,722
    Poole, Dorset
    Country:
    That is the problem.
    Either it is wired wrongly, or it is the wrong device to be using on a dual supply.
    The model suitable for dual supplies is the BX2000
    http://www.tlc-direct.co.uk/Products/HOBX2000.html
  4. bernardgreen
    bernardgreen
    3 Nov 2006
    23,767
    Thanks Received:
    2,291
    Bedfordshire
    Country:
    Do you mean you have connected the Live from the fused spur fed by the economy 7 supply to the same contact in the timer as a Live supply from the fused spur fed by the normal permanent supply ?
    Just be glad the RCD tripped out. That link you put in would have carried all the current required by the economy 7 equipment. If you have any storage heaters then they would have been permanently supplied via that link.
    That could create a hazard and large electricity bills
    If youhave a dual rate meter for the econony 7 then you only need the permanent Live feed to the timer. All the power used from the permanent supply will during the economy 7 periods be charged at the low rate.
    Only if you have two separate meters would you need to make special provision ( two controllers ) for the two immersion heaters.
  5. sijaysee
    sijaysee
    8 Dec 2005
    344
    Thanks Received:
    Cornwall
    Country:
    yea bernard both lives are wired in the same terminal in the programmer. the economy 7 is seperate from the the other immersion circuit. so the only way is to use 2 programmers then?
    Si
  6. kai
    kai
    You need a compatible unit, which electrically isolates the night and day supplies, so that the boost can be used independently of the night time circuit, so that current from one circuit does not backfeed into the other, causing possible danger, and RCD to trip out.
    ALternatively just have the timer controller on the bottom night time circuit, and just use the 13amp DP fused spur switch to control the top booster element, as was the case on my old home.
  7. westie101
    westie101
    3 Jan 2011
    2,497
    Thanks Received:
    313
    Cumberland
    Country:
    The impression I get from the OP is that the lower immersion is fed from the E7 CU so will be controlled by the electricity supplier's timeswitch anyway as the storage heaters will be). The upper heater is for topping up during the day and fed from the on-peak CU
    So there is no real need for a controller if this is the case
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
