Hello, my first post so here goes!
I have recently inherited a flat which had both economy 7 heating and hot water on a white meter. These radiators and the long immersion element seem to be on a separate circuit from the other household appliances - as the circuit is dead during the day.
I'm intending to rent the accommodation and, because most people who would be renting it would tend to work during the day, I've replaced the heaters which were mega old, bulky and unsightly for conventional convector heaters with no night storage on the ordinary ring main. The hot water tank, however, is still on the economy 7 circuit (for the main immersion element).
So it looks to me as though my tenants would be stuck with heating their bathwater at night, even if they were only going to use it the following evening.
There an old HORSTMANN control (mechanical cam type) on the kitchen wall which offers a timed economy 7 function and a boost using the shorter element.
I've read elsewhere that devices such as a washing machine, if used at night, would operate on the economy 7 tariff even if they are plugged into the normal mains circuit. Would that be true with my setup?
If it's true, then, is there any way that I could get my HORSTMANN controller to work such that, like the washing machine, it would allow the longer immersion element to operate during the day on the normal tariff and on economy 7 during the night? I'm thinking that a tank heated during the night might be fairly cold by the evening. Also most economy 7 tariffs wouldn't be the best choice if you're only heating the water and doing no night storage would they? So if you weren't on an economy 7 tariff it'd be pretty unsatisfactory to have to think to turn on your long immersion element the night before you wanted a bath.
