I have recently moved into a new flat which has a worcester 24cdi combi (i think that's the correct model) and the hot water flow is terrible.
I used a bucket to measure the cold water flow rate and the hot water flow rate and got the following:
Cold: 8.5l/min
Hot: 3.2 l/min
I was under the impression that the hot water flow rate should equal the cold water flow rate on a combi system?
Also another issue i have with the hot water is that the temperature fluctuates greatly - if i have the temp on the boiler set high, then it fluctuates from very hot to completely cold, and if i set the temp on the boiler to the lowest it fluctuates from lukewarm to hot (flow seems constant).
Any ideas on what the issue is? I got BG round to have a look and they replaced an incoming valve and it didn't make any difference. The guy blamed the problems on poor water pressure, which i thought wasn't right?
Thanks for any help,
Priesh
Cold: 8.5l/min
Hot: 3.2 l/min
Priesh
