I have a Potterton Prima F 60 (not a combi boiler).
I have been using the hot water on a daily basis. I recently used the central heating and it works fine. At roughly the same time (coincidence?) the HW stopped working.
When I turn on the HW, the boiler fires up, the pump comes on and the HW motorized valve opens. It stays that way for a few minutes and then everything turns off. As far as I can tell the cylinder thermostat is working. It clicks at about the right temperature and (I think) sends the right signal back to the control panel.
I can force the HW on by turning on the CH and manually opening the HW valve.
Anything else I can check?
Thanks!
Thanks!
