hot water cycilder not heating up!!!
15 Apr 2012
Hampshire
Hi . i had a new cycinder put in a few wks ago . Since then am having problems with my hot water supply , am not getting any.. I had everything checked and checked again and everything is working ok . My electrics are all ok but yet the cycinder is not heating upp the tank of water . i have storage heaters.
Can anyone helkp me PLEASE.
Thanxs james
Hi ok . i have storage heaters in my house, My water and heating heats up during the night, I never had any problems until i had a leak at the bottom of the cycinder .
I had a new one fitted with new elements. but since then i still dont get hot water ?..the elements and plugs and wiring have all been checked and are all ok, working fine. . The light comes on at 12.30 am to start heating the water and goes of at 7 am but water does not get hot . My storage heaters get hot during the night .
in the morning i may get about 2 mins of hot water then cold. The out pipe gets hot also.
anymore information you need just ask. thanxs
any idea just what length Immersion Heater was put in?, If it is top-mounted a 27" one might be suitable, whereas a mere 11" (ooh-er-missus) may give the symptoms you describe.
DH
Am not sure . cycinder is 900x450.. When i put the immersion switch on to boast so i can get so0me hot water, that does not really get the water hot, just warm then cold .
thanxs
Has the re-set button tripped in the bottom element?
Remove the cover and take a picture.
Andy
Better to call the installer to sort it out!
He seems conspicuous by his absence!
The installer has been over last wk and said it was my wires not commecting. since then i had them looked at and everything is ok with them ..
Need to call him out again..
Thanxs for replys.
james
Has anyone any idea what the problem coiuld be ? please.
thanxs
I think that your installer coiuld be rather lacking in certain skills!
My price for supplying and fitting a new cycinder is usually about £460.
Was your installer much cheaper?
But then I do the job properly and sort out any problems which may arise.
