hi all
ok i know there are a few threads relating to this subject but not quite the same setup as i will have so i need to ask a few people who can answer these questions for me
1. i am not sure i can get the clearance to fit the hwc into the loft with enough eaves space to get the cwt above it. my other option is i have a cupboard fitted above stairs which is generally a dumping ground and was wondering if it could be relocated into there with some additional strengthening.
it will be raised up around a metre from where it currently is but will still give at least 60-100cm between the top of the hwc and the cwt, my question is how heavy is a full tank? i cant seem to find any guides as to how much it would weigh and if i knew i could then work out if the repurposing of the cupboard was possible?
many thanks for all your info its greatly appreciated
