I have an Worcester 28i boiler (16months old) and in the bathroom upstairs when I put on the hot water it doesn't get very hot unless I turn the tap to be about a quarter turn rather than fully open. It seems that somehow the pressure once increased (by me opening up the tap fully) stops / reduces the hot water to flow freely. So I end up running a bath for hours instead of minutes!! The CH system seems okay. Yes did lose some pressure in the CH system a few months ago - but once I added more water to the system is seems stable...famous last words!!
I also suspect that the water pressure coming into the house may be set too high (we had some building work done and the builders messed about with the water suppy) - as I hear a banging noise should I quickly turn the cold water tap fully open and then off. Should I go outside the house and turn the water pressure key a quarter of a turn to eliminate this?
Any help from anyone would be good.
