Hot water in FE tank
17 Oct 2009
Kent
I've seen several posts on this but to clarify please.
There is hot water coming out of the pipe that hangs U shaped over the expansion/feed tank.This tanks water level is about 2 inches from the top as it's been filled from the overhanging pipe and pouring onto my drive at open tap rate.There is also steam and general wet around the area. I notice that it's only doing it when the CH is on and first thing in th emorning when it's been on for 10/15 minutes it makes a terrible racket in the loft bubbling and steaming.
It's venting from the copper tank I guess?
Don't really know why or what to try first?
I have knocked the pump from 2 to 1 and knocked the Tank Stat down to 45 from 60.
4 yrs ago new copper tank
1 yr ago new pump
1 week ago new 3 way valve
Any help greatly appreciated
Thankyou
Stewart
It's either piped wrongly or there's a blockage in or around the cold feed/open vent area.
Your system will need, at least, a chemical clean, more likely a powerflush
Are there cold spots at the bottom of the rads?
Start with a chemical flush, Kamco's Hyperflush can be left in for a month.
turn the boiler stat down to minimum and see if its still the same.
