If it is a three port valve if I remember correctly it defaults to hot water only with no power, but the boiler should not be on. I believe the boiler is switched by the programmer for hot water only, or HW and CH, and by the valve contacts for central heating only. If it is S-plan(independent 2 way valves) The boiler is normally switched by the motor contacts.
