- Glow Worm Hideway 100 boiler (18 years old)
- CH system fitted with Grundfos Selectric Mk II pump
Problem: Until a few weeks ago we could get hot water by having only the hot water switch on. However, some of the radiators were also getting very hot.
Now we can only get hot water by switching on the CH as well.
I have checked the flow of water through the system. With only HW on, the flow goes one way. With CH on, the flow is reversed and I guess the HW is making it to the tank thanks to the pump pushing it round the opposite way.
Without the CH / pump on the hot water should be going straight from the bolier (in the kitchen) to the tank which is located above in the bathroom.
With only HW on, the pipes to the bathroom are only hot for around 1 metre and the return pipe is significantly cooler. The two central heating pipes are red hot.
Obviously, now is not the ideal time to have the CH on just to generate hot water.
Any help or ideas would be greatly appreciated.
Thanks in advance.
Thanks in advance.
