hot water only when central heating on
8 Sep 2009
Blackpool
had valve pump replaced yesterday on my glow worm ultimate central heating now works fine but hot water will only work when the heating is on
by who and why :?:
and what do you mean by valve pump :?:
Did the engineer not test the boiler? :confused:
he tested the boiler with both the heating and hot water on at the same time but not on their own.
That is rather unusual. He was either in a real hurry to get out the door, or he knew perfectly well that he had bodged it, and just showed a working boiler to "prove" that he had earned his money.
When you change a diverter, you test that the diverter works by testing first heat only, then dhw only, and then both.
What was the reason he changed the diverer in the first place?
