Hi... As the title says really.... The hot water just doesn't appear to work unless the heating is on at the same time.
Boiler is a Baxi Bermuda 552. A back boiler with an oldish gas fire on the front.
hot water cylinder is in a cupboard almost directly above the boiler/fire, and tanks are in the loft almost directly above that.
The programmer/timer is a Hortsmann H21.
It's basically always been like this, I've been using the immersion heater but this is obviously expensive and a good way to kill elements.
I'm a fairly competent DIYer but don't have much experience with this kind of stuff. I've helped move a Radiator and install an electric shower but that's about it with regards to plumbing really. Done a reasonable amount with electrical stuff though. Just looking for some ideas as to what might be the problem with this.
Thanks for reading!
Thanks for reading!
