Hi My first post on this great site. My system is a
Vaillant ectoc plus 28
unistor
VR 65
VRT 360 f
Honeywell V4073A Mid Valve.
Main problem is when I have hot water and heating on system will only heat the HW, once HW is up to temp, CH will then heat up. The VR 65 is wired up as per manual. Boiler set up D 70 is set to 1, mid valve position. I contacted installer several times, tells me it is working fine. Same guy who told me the s53 code was my pipe work, But after checking this site found it was a setup problem. Any help or in fo the hot water problem would be great. Thanks
unistor
VR 65
VRT 360 f
