HOT WATER PROBLEM
2 Jan 2013
Worcestershire
Mate text me this earlier:
When Im filling the bath up the hot water stops all together after a few inches in depth. I googled it and it sounded like an air lock. So I sent cold water through the pipes while leaving the hot tap open. This seemed to work at first and hot water started again. Its happening every day now, I have to send the cold through the taps again for a couple of minutes to get more hot water.
Its not a combi boiler, I have a water tank.
Any ideas to help
Check the water level in the cold water storage tank in the loft. It sounds like the ball valve is either stuck on something (causing a very low level of water in the tank). or the tank is re-filling very very slowly!
