Can anyone explain this to me
Worchester Bosch 35CDII combi boiler - about 10 years old.
Had a few bits replaced in last year....(including a valve to heat exchanger (IIRC) and external expansion vessel)- settings will have been changed - I think maybe water feed pressure increased (we have v high water pressure, have it turned down on stop cock and think it used to not be turned fully on into boiler) - sure it didn't used to be like this....
In Kitchen hot water gets really hot -too hot to bear...(although has had a new cartridge on this tap too...)
In bathroom doesn't need any cold when running a bath...never gets very hot. Just tried to fill a jug of hot water in bathroom and must have run gallons of water ...never got above lukewarm and then went cold.
Boiler is upstairs probably about the same distance from bathroom as kitchen...both (I think) feed to and then from where hot water tank used to be when old boiler was in.
I think feed to kitchen is 22 mm - whereas to bathroom is 15 mm ...
Any ideas?
Any ideas?
