I've just had my old oil-fired boiler (a Worcester Danesmoor 12/14 - 48000 BTU) replaced by a new one (a Grant Multipass 70/90 - set at 80000 BTU) by the guy who normally does my boiler servicing. He's OFTEC registered, and has always seemed knowledgable and reliable, but I now have some concerns.
My house was converted from a 2-bed bungalow to a three-bed house by the previous owner, via an extension on the back and a loft conversion - so it's now about twice its original size. The existing boiler had been retained, but was over 15 years old, and I assume undersized for the enlarged house - hence the larger replacement boiler. Also, all the pipes to the rads are 8mm microbore, though there are no manifolds in the system. It's all controlled via a "Honeywell Y Plan" system - actually an ACL version.
My first concern is that after he'd unpacked the boiler, he noticed that it was labelled "Sealed System" and was therefore the wrong type. However, he then said that he could still use it (basically by removing the expansion tank and bypassing the pressure system). Is this OK, or a bodge?
My next concern is that the spec shows that the input and output pipes should be 28mm - mine are 22mm. Also, although he drained the old system (obviously!), he didn't flush it as the water coming through was pretty clean.
Next up is the real problem. The system gurgles a lot, and I have had to do a lot of radiator bleeding. Then today I realised that, with the system running, the bleed valves on the upstairs radiators were actually sucking air in rather than blowing it out. A trip up to the loft revelaed that hot water was constantly pouring from the vent pipe into the header tank.
Because the new boiler had an integral pump, he disconnected the existing pump in the loft. Now I suspect this is where the problem lies. The output pipe goes up to the loft, and the vent pipe runs off it, and then the main pipe goes on to the motorised diverter valve. The existing pump had been fitted to the other (non-boiler) side of the vent pipe. Now, by using the internal pump, the pump is on the boiler side of the vent pipe. I'm by no means an expert on central heating systems (but I'm learning fast!), but it seems to me that pumped water facing a choice between passing up a 22mm vent pipe or going round the system would probably prefer the former. Most of the rads are working - apart from two new ones he installed. However, hot water still goes through the vent pipe even when on hot water only.
By reducing the pump speed from the no 3 setting to the No 2, the flow of hot water through the vent pipe is still present, but reduced. This seems to support my feeling that the pump should be the other side of the vent pipe. However, if this is true, then for him to have consciously created this situation is causing me to wonder whether he knows what he's doing. And hence I'm starting to get concerned about the other points mentioned above too.
One other detail - he had to replace the motorised valve as the existing one was seized.
Finally, the installation guide for the old boiler says that there is no requirement for a system bypass - and there appears to be none fitted. The guide for the new boiler doesn't mention this, one way or the other. All the rads have TRVs - should there be at least one without to provide the bypass function?
Sorry for such a long (first) post - but I would really appreciate some expert comments on this to either put my mind at rest, or to prepare my arguments for when he returns to complete the boiler commissioning and documentation.
Many thanks.
Many thanks.
