Hi
I moved from a conventional boiler to a combi - Worcester Greenstar 30i (two bed flat, with one bathroom). Everything works fine, heating, hot water etc. The only problem is when I try to run hot and cold water together the boiler switches off and no hot water comes through (the flow of water from the hot tap doesn't change). To be more precise I can turn the hot water tap on in the bath and hot water runs, nice and toasty. The moment I turn the cold water on, the boiler turns off. The thermostatic shower does something similar but I don't even get any hot water, the boiler initially starts up the moment you turn the shower on but then instantly stops. In the bathroom sink the cold and hot taps are separate taps. If I run the hot water in the sink it runs hot, when run a cold water tap anywhere in the flat the boiler switches off (again the flow rate barely drops). I initially thought the flow was dropping and the boiler was turning off but the flow from the boiler seems fine....
Any ideas what the problem is and are British Gas liable to rectify the situation as they installed the boiler?
TIA
Andrew
TIA
Andrew
