- Joined
- 5 Apr 2004
- Messages
- 121
- Reaction score
- 6
- Country
Hi Folks ,
Recently we have had to have a new cylinder in the boiler its a worcester bosch as it kept losing pressure and a new pressure release valve , i would also say around 12 to maybe 24 months we had both valves replaced on the pipes that lead to the heating and the hot water storage tank to allow water to flow when the system is turned on .
So i come in yesterday and wife says no hot water !! .
Sure enough the storage tank is freezing , i check the centaur control panel and boost the hot water for an hour the boiler doesnt come on at all and the storage tank is cold as ice on all the pipes leading it from it as well . I turn it all off and turn it back on again still no luck .
I then think its got to be the thermostat on the boiler its been on there for years . It does look a bit discoloured on the plastic round the base where it actually touches the tank .But i turned the thermostat and it still hasnt turned the boiler on and yes it was at around 70 degrees not 0 .
When the thermostat turns all the way off and back on again it does click i would say around the 35 degrees mark but poss less .
Because the thermostat clicks does that mean that its 100% o.k as this is the simplest thing for me to change myself for £15 without calling the plumber in . But i dont want to waste even £15 if the click means its o.k .
If it isnt the thermostat on the boiler am i right in thinking that it has to be one of the main valves on the pipework even though they are fairly new , will be irritated if its one of those they dont seem to last 5 mins which ever brand you have .
One more thing with those valves is i thought the boiler had to actually switch on and fire up to send the electronic message for those valves to open or am i wrong on that as the boiler isnt coming on .
p.s Tested the boiler with the CH side and it works fine .
