Hi there everyone
heating systems id the one thing i pretty much know nothing about, so i need your help.
i noticed on friday that my overflow from the cold feed tank on top of the hot water tank has started over flowing. the ball cock on the cold feed is fine and shuts off way before the water level reaches the over flow.
however the water level then continues to rise slowly and then starts to trickle out the overflow to outside.
if i listen very carefully i can here the cold water running, so it must be coming from somewhere??
it doesnt matter if the heating and hot water is on or off it still continues to fill up.
if i run the hot tap it drains down again. but then the process continues.
im aware of the hot water tank releasing the expanded hot water into the cold feed tank but as the boiler is not on and the water in the tank is not at all hot i dont think this is the case.
as i have said i know nothing about heating systems.
i have a little glowworm boiler that i think feeds the hot water tank thats about all i know.
heres a picture that might help.
green arrow - the cold feed, ball cock is fine.
red arrow - the overflow
pink arrow - pretty sure thats the hot water out
orange arrow - not really sure, water in?
blue arrow - coming from bottom of boiler which i think is whats filling up the cold feed tank on top.
there is also another pipe around the back that goes up to the cold feed tank that i believe vents the hot water tank into? this above the water level in the cold feed tank but nothing is coming out of it.
help and advise would be great please
also if you could explain in laymen’s terms, as technical words for stuff with it all will go right over my head
thanks in advance.
thanks in advance.
