Hi, i hope someone can assist. We have taken the old sink out in the on suite and capped the pipes off until we put the new one in.
In the airing cupboard is the hot water tank, there are 3 pipes with red screw taps. One for the hot water, cold water not sure what the other one is for.
We turned the hot water tap off before and this was ok. When we went to turn is on the tap and thing its connected to turns but nothing happens. You can just continue turning and it will not tighten either way.
We moved into the house about 3 years ago and when we first opened this tap it was very tight and needed a wrench to open it
any help would be appreciated, may thanks
