Hotpoint 1200 spin - Refused to drain water
17 Apr 2005
Can anyone suggest to me what to do. My washing machine refused to drain water spinning. This is the first time i am experiencing such. :?
does it drain between rinses?
it may be you filter is blocked or the pump has had it.
i would suggest check filter first.
filter is connected to the pump, under m/c, unplug and remove all pipes put m/c on its back, you can then safely gain access to pump and filter
