I can usually fumble my way through and fix most things that break in our house but this washer/drier has got me stumped. It's less than two years old and has been totally reliable until the other day when this fault materialised. The cycle seems to be stuck on the last spin, it will run down from the spin and churn away for a while then the function lights (spin and door locked) go out for a couple of seconds and the machine starts churning again - lights go off then on and machine starts churning again. This will continue for as long as the machine is switched on so I tried to reset it by switching it off at the wall, unplugging it, leave for as long as you like (over night in one case) but when it's powered up again the spin starts and the same problem occurs. I've checked the obvious - pump filter, blockage on level switch, anything loose but to no avail so I'm hoping someone can shed some light on my problem.
Thanks in advance
John
Thanks in advance
John
