Hotpoint Aquarius, TL21 Tumble Dryer
4 Feb 2006
Coventry
My wife has just put some clothes in the tumble dryer.
The drums turning but there is no heat on either setting.
Replaced the 2 Thermostats 2 years ago, could it be the same fault?
I note from the "Hotpoint online" spares dept. there's another thermostat in the machine, 58 degrees any ideas as to its whereabouts & its function.
Many Thanks!
Kettle 3 :confused:
yes most possible ,check for continuity across the stat if it dont bleep it is open circuit you can reset them by thowing the stat on the floor a few times so the disc is not concaved but if it works for 5 mins then goes wrong you have other problems but you must not reset stat again till you find the cause :)
