Hotpoint Aquarius WF220 pressure switch fault ??
12 Mar 2011
Southampton
Hello,
My Hotpoint Aquarius WF220 washing machine stopped working ! After taking water for few seconds it stops doing anything and three diods are flashing :
Power , mini load and rinse hold - which indicates :
f10 lights 1&3, pressure switch not sensing
I have checked drains checked pump chamber ( found some coins...) I also cleaned this small pipe leading to pressure switch. No success !
I have been adviced by large online spares shop which pressure switch to order and so I did. The part that came looks little bit different to the one I had. There is a different layout of things but I mounted it in and - the I got the same error.
I am confused... Help ! :oops:
It's a Pcb fault. Make sure connections on Pcb are tight otherwise Pcb time. Emw is good for a recon one.
