Hotpoint Aquarius WF321 - 2 lights on console
7 Sep 2014
Hi all,
Our washing machine has developed a problem over the last couple of days..
Basically when you start a wash the wash light illuminates (as usual) - then between 2-3 minutes later the door lock light flashes. The wash light stays illuminated and nothing happens from there on... I can confirm the door is properly closed.
I took out the PCB but there's no obvious signs of damage on it. My proper multimeter is at work so I won't have access to that until at least tomorrow evening so I can't test the caps but they look OK!
Does anyone have any idea what the above symptoms could be relating to?
Many thanks,
Dale
Hi there,
Thanks for that!
I know next to nothing about motors etc -
Do these brushes look worn?
Many thanks,
Dale
hard to tell in their holders, but I would expect to see more than that sticking out so I think they probably are. New ones are about 40mm long, so anything less than25mm & I would change them.
