Hotpoint WF541 (door lock, Wash & on lights flashing!) H
28 Jun 2013
Norfolk
Can anyone help. I've just moved into a new house that has a washing machine already here. A Hotpoint Aquarius WF541.
I've just gone to use it for the first time, it took in water for about a minute or two....it then stopped, and three lights started flashing. It hasn't done a thing since & the washing is stuck inside!
The three lights that are flashing are the "Door Locked" light, the "Wash" light and the "On/Off" light.
I've tried switching it off, unplugging it and trying again but the light illuminate & then start flashing again.
Please can anyone help!???
does it have a drain cycle you can set it to so that you can drain the machine and at least unlock the door/get your washing out?
it won't let me do anything....if I put it on the drain cycle, it just makes a random whirring noise and almost all the lights starts flashing. But no draining and no washing :(
I've got the printed instruction manual, but is says nothing anywhere in it about that combination of buttons flashing.
It only gives light combinations for things like 'door not shut/shutting properly' or 'machine failed to take in water' or 'blocked filters'......none of which are the problem.
I'm at a bit of a loss really after searching the internet for answers.
I wonder if the circuit board or something has gone cuckoo seeing as it hasn't been used for a few weeks!?
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light in your one error fo1 pcb gone ex pcb from here http://www.emwelec.co.uk/index.php?action=category&id=1
