hi
my washing machine keeps tripping out the electrics to the house.
i have disconnected the power socket to the motor and everything seems fine. as soon as i plug it back in it trips the electrics, so i assume it is the motor. i have done a ohms test from the armature where the carbon brushes connect and to earth and i am getting a reading, i dont think this should happen do you?.
any way i have tested the inner windings with an ohms tester they seem fine as i am getting a continuity reading, i have also tested the windings to earth and get no reading so i assume that is in order.
so it seems to be the armature at fault. i even stripped the motor down, connected my ohm tester to the armature rod near the bearings and to the carbon brush end and im still getting a reading.
could this be fault. also the machine works perfectly when i disconnect the earth to the motor althogh the motor comes live. so it has to be the armature?????.
any help please
regards
any help please
regards
