Hotpoint Aquarius WMA54P wont pump out
26 Aug 2006
Surrey
Hi
My washing machine will not pump out. At first i thought it was the stand pipe, but i have tried to run the washing machine draining into the sink but it wont pump out. If I drop the drain hose to the floor it run out okay.
I have taken the small back panel off but cannot see only filter or anywhere i can check for the pump being blocked.
any ideas please
many thanks
Hi
the pump makes a noise( not the same as usual) but nothing pumps out. i feel there my be a blockage but dont know where to check? there seems to be no filter to check when taking the small back panel off?
any ideas please many thanks
I think if the pump is running, you need to find is the water getting to the pump, so is the blockage before or after.
Saying that you say the water will drain if you lay the pipe low, so there is no blockage.
I think the pump may have failed, no impeler.
Hi
just to let you know. pump was blocked even though water was coming through. The pump slides off the bottom of the machine and can be taken apart without disconnecting the hose in and out. once apart the blockage can be removed.
25 minutes £40
regards
