hotpoint christmas tree
19 Mar 2006
Wolverhampton
Having a right week this week just replaced a new pump on my sisters hotpoint wm when as i was leaving had call from father in law saying his hotpoint wont open and all of lights flashing :cry: ,done a search on here first and found a thread reguarding a capasitor on here so orderd them and went up today and done the soldering but still no joy or change .Its a hotpoint wml520 and what happening is once you turn on at plug the empying pump runs for say 3-4 mins then all bottom lights flash rapidly and two other
would you recommed me order a new board for him or could it possibly something else which i could try first any help would be much appriciated
C17 cap only works on wf and wd models. Yours is a wml. You fault is a blocked filter/ pump or waste spigot.
oh :shock: thought id try it anyhow as its a 40 mile trip to his house ,in reguards to a blockage ive check every thing pump removed and all gaters checked and clean also outlet pipe clear ,could the inlet valve be faulty as i know he has a brand new one somewhere as his cracked before and i got him a new one but fixed his before it arrived but we couldnt find it tonight :(
Does it fill ,does it rotate does it empty very quickly cos that error code means is got a blockage. Did you check the sump the ball may have got stuck with a colour catcher or sock.
hi rocks no it doesent fill no water at all just the pump runs for a few mins before all the light starts flashing ,i did check and clean the ball and all the gaiters around the pump also blew and sucked to out left pipe :? which was clear and drums perfect ,im sitting here kicking myself now as i have the feeling im going back up there tomorrow to find that inlet valve which hes put somewhere
If the drain hose is not down too low and u have cleared all plumbing then u have a pcb fault. Call manufactures all in charge parts and labour £100.00
Make sure it's programmed to that mc , there's 5 different versions of pcb. If it turns up with a blank EPROM then you will need a smart card £10.00 and a card reader £120.00 to program it
