Hotpoint CTD00 starts and stops
4 Nov 2009
Antrim
This is a great site with lots of useful advice. :)
I have a problem with a Hotpoint t/d CTD00.
When switched on - with nothing in drum and condenser out - only the pump runs. This lasts for ~ 4/5 minutes then the drum turns but only for ~ 5 seconds and then stops! This repeats but at no time does the heater heat or drum stay turning.
No water in tray or pump area, the 2 reset switches are closed so I think I have tried everything obvious.
Grateful for any help or advise...... :shock:
Ta
cap needs changing found next to the motor. right hand side panel removed. also remove the lid spin drum by hand to start it up then it will run.
Thanks rocks1 - you are a great help as usual. :D
I changed the cap and drum turning normally but still no heat.
The switches above heater look ok - they spring back closed when you push in - maybe I will change them anyway as cannot see what else would cause problem.
Does anyone know of best place to get CTD00 heater reset switches?
just need to reset them take the rear banjo cover off on top is 2 round small stats ,the one on the left has a small hole in it push a safty pin into the hole till you hear a click job done . :)
no dont buy it just remove stat and throw it on the floor to reset the metal disc . when disc is pushed out its done.
Thanks rocks1
Tried that - job done and heater now working :D
I did not finalise the order so saved myself £20 - thanks again.
Great site esp. if you have duff Hotpoint.
When replacing at some stage think I will go for Bosch or Zanussi - would these be better makes?
bosch is good ,you get what you pay for .a few quid more gets the better ones . :)
