Right pump is jammed with poss glass or china or food. As I said before you can remove the filters that White bowl under them is the sump. In the corner is 3 slots push a metal coat hanger in one of the holes and give it a good tickle / flick it may need doing 2 times to clear it. Them shut the door. And press start pump should hum when it does job done. If you can't do that bit tip mc inside done with towels on the floor and remove base 3 screws and follow waste pipe to pump. Undo one screw and twist off also remove waste pipe this has 1 clip round it clean pump and don't loose the black o ring on pump face refit and it's done.
right tipped it, unscrewed the 3 screws and the 1 screw and twisted off the pipe after taking off wasted pipe checked it all but nothing there. put it together and started it and the same as before you hear the water come in no spraying and then few min and the heater starts and then the bubbling then the mc cuts off over heating. i think it is time to give up a save for a new dishwasher.
Thank you again for your help.
