Hi.
I hope someone might be able to offer some advice...
we have an 8yr old Hotpoint WMA58P washing machine from new. recently it was getting really noisy on spin, so i bit the bullet and ordered a set of drum bearings and thought, while i've got it apart, i'll replace the motor brushes for good measure.
Taking it all apart, i labelled both the connections and the plugs so i knew where to put everything back, then stripped everything out. I successfully replaced both the brushes and bearings and put it all back together. the washer worked before i took it all apart, just very noisily. While dismantling it, I noticed the motor brushes had ALOT of soot and were very worn. there was black carbon dust in piles on the floor of the machine. good job i bought new ones!
after putting it all back together, I turned it on, put it on a spin cycle and this is where the problems started.
it fills for approx 5 seconds and then the light to show which cycle it's on goes straight to "end" but the door doesn't unlock. if i choose "!" on the dial, it will empty continously but not stop. If i power off / power on and choose any other cycle it does the same, fill for 5 seconds and then goto "end"
I've tried putting the old motor brushes back in and also tried disconnecting the heater incase that was stopping the cycle. i've blown down the pressure tube and there's no blockage, i've blown into the pressure switch and can hear click when blowing / stopping.
At no point does the motor spin or agitate, but i don't believe the drum is filling up as much as it should do. previously the fill time was definately longer than 5 seconds...
I've spent an hour googling for answers, checked several forums and read http://www.washerhel...lp_4.html#cl_q2 before asking for help, still cannot seem to find the answer
Thanks in advance,
josh
Thanks in advance,
josh
