I have a Hotpoint WF250. The water heating has packed up, and while investigating it appears the machine is also not taking hot water in from the inlet, only cold. Have swapped hot and cold water inlet pipes and machine cycles fine using only hot water (including rinces) so supply is good.
Questions:
1. When (which cycles) should the machine take in hot water?
2. Maybe the hot water solenoid is broken. How can I test it? It's not possible to swap signal cables between hot and cold solenoids as connectors are keyed.
3. Does anyone know what signals appear on the two solenoid wires when water is called for?
Many thanks.
Questions:
Many thanks.
