Hi, My machine seems to have a similar fault to others that I have seen on here. The only difference is that the symptoms are not identical each time we switch on, ie different lights flash. on different occasions. The result is a non working machine until (at the moment) after repeated switching off/on at the wall it will eventually work ok. I am assuming that this is the circuit board on it's way out. Can anyone confirm this or give any other advice.
