Hotpoint wf540 washing machine
21 Oct 2008
Kent
On/Off lights were flashing, have cleaned the filter and now final spin light comes on when machine is turned on but machine does nothing, HELP!
any other lights flashing on the left :?:
unplug mc for 2 mins then set prog on pump out does the pump come on :?:
No, nothing happens and final sppin light is still on
looks like you have something jammed in the pump hairclip/ coin .unclip pump and pull of the two hoses and flick impeller see if it turns
Thanks for the help
Can you explain where things are please
when u cleaned filter at the front and unscrewed the cap look inside you will see a white impeller give it a flick round and see if it turns .if its jammed take the 2 screws off and pump drops down,then you can see whats in it
we followed your instructions for Lisa R. and cleaned filter at the back, where is the filter at the front/
ahhh this filter is at the back ,right next to it is the pump with the grey outlet pipe /waste unclip it and look inside the pump ,thats were the prob is
grasp pump in hand and pull to the left at 9 oclock tilt mc forward and you will see clip underneath
Thanks for the help,still struggling trying to unclip.
Will let you know tomorrow if we are successful,
thanks again
Thank you so much for your help.
The machine is working fine now after following your instructions.
You're a star and I hope I can return the favour one day
Thanks once again
