Hi, recently my washing machine has started flash lights 2 and 4 towards the end of a cycle. The water does not drain. I have done my research and this error code points to a possible pump blockage. I have checked the pump at the front bottom as well as the drain pipe that goes to under my sink and both are clear and water passes through them. Im beginning to think there may be a blockage/problem elsewhere. Where else can I check?
