Hotpoint wm80 bearing replacement
24 Jul 2005
Leicestershire
I have stripped the machine down and from the rear view, I have removed the nut enabling me to remove the belt, wheel and then I am left staring at the bearings.... How do I take then out to replace and also the spindle - I tried everything
Help
you need to split the outer drum so you can remove the inner drum.
then its a case of drifting out the old bearings and seal carefully and checking the spider to make sure it is not damaged (and the drum shaft)
