Hotpoint WMA34 Aquarius noisy when stationary
11 Nov 2009
Northumberland
Hi guys
As described above it make a 'buzzy' noise when it is stationary. It does it during final spin and continues until the drum stops then continues for a bit more. It is loud enough to here from another room. It also has started to walk across the kitchen during a fast spin but Im not sure these 2 things are related
Any advice is greatly appreciated
I am technically competent so self repairs shoudnt be a problem once I know what it is
check the pump for a bra wire /cotton bud.
Thanks for that
I assume the pump is at the rear at the bottom ?
I have never taken one apart before
Remove the top 1st then look at the sides for screws to remove?
no not the sides. remove rear white cover down the bottom .drain hose is connected to pump in the corner. undo 2 hoses and look inside the pump .
Hi
adjust the legs see if that solve the problem. if not then adjust the two inside jumper. You have to open the back panel to get in to it. If it noisy then is the baring is gone. That is a bit big job. Good luck
A buzzing noise once the machine has stopped could indicate something going on the door lock. This prevents you opening the door for a set period after the cycle has completed. :)
