Newbie here and I need help with a problem. For reasons I won't go into I've been left without a washing machine for Christmas by a company called Glotech!
I had a fault with the door lock that they came out and 'fixed' two weeks ago, only for it to go again today! I have managed to fix the door lock but I removed the door rubber seal from the drum instead of from around the door! (Schoolboy error) I can't get the 'spring' that holds the rubber in place back on the drum. I can get it half way around but I need to take the front panel off to get it back on the bottom!
I have watched countless you tube clips but none are for my machine and are all different! Does anyone know how I can get the front panel off the machine? I have removed the top but the control fascia won't budge as the soap tray removes but leaves a white plastic 'casing' also I have removed two screws at the bottom of the front panel but they have done nothing!
Any help would be greatly appreciated!
Thank you
Paul
Thank you
Paul
