I have a family member who has property in Spain where code requirements are not exactly strict
The septic tank smells in the house.
There is a section of the plumbing for the main waste pipe that comes from the house and runs a150ft +(slight angle from horizontal) before running down 20ft into the septic tank.
There is either a problem with the venting at the top of the house - the pipe does not extend beyond the roof but rather into a little roof cap or some other issue with an open pipe in the wall cavities.
No-one knows if there is an open pipe in the house (in the concrete cavities) or some other problem but when the central ventilation/AC is turned on, septic tank smell comes out of the AC vents. You can also see a vent installed near the tank in the picture below which doesn't seem correct - this is an outside open to air room but the vent should clearly not be there!
To try and improve this, they added a vent in the main waste pipe and knocked a hole in the wall of the house underneath one of the toilets!
I can only assume this was a way to increase the ventilation of the tank but it has made no difference.
Can you add a p trap in a long section of 125mm pipe or will this cause back up problems?
