I want to add 4 Bulk head lights to a long outside wall (60 watt each)
I have a mini CU in the garage which i would like to run the cable from.
This has two MCB 1: 6A Garage light and 1:16A for a double socket.
What is the right way to do this- my first thoughts where to change the single light switch for a double and run 1.5mm T&E to the lights in turn.
Is this right and will I need to change the MCB for a higher rating.
I am tempted to just get an electrician in but I thought this would be fairly easy for a beginner??
