How Can I Remove This Mixer Tap?
29 May 2004
I have a leak at the base of the kitchen mixer tap where it goes into the sink. I can remove the spout easily but I can't get the base bit off.
Under the sink next to the hot & cold pipes going up through the sink to the tap is a black rod type thing. It seems to be made of hard plastic and it has a hexagonal end with a slot in. Does this unscrew to enable the base of the tap to come off. I have tried to unscrew it but it seems stuck and I don't want to force it. I have attached a couple of pics to show the black 'rod'.
Any help would be gratefully received.
Thanks,
Paul.
yes it undoes.
Socket set does it, see post currently one above.
If you havent got a socket set 'MONUMENT TOOLS' do a monotap back nut set for £3 odd. available at most plumbing merchants.
