How do I calculate water volume in CH pipes
14 Sep 2004
:?: I'm trying to size an expansion vessel for an unvented cylinder and I need to work out the total water volume of my CH system.
I have got the calculations for most parts of the system but can't find anything on how to calculate the water volume of the pipes.
Can you help out? I need the "per meter" volume for 22mm and 15mm pipes.
Volume of a cylinder is area x length. Or pi x radius(squared) x length.
So, for 22mm pipe, one metre will contain approximately:-
3.142 x .0022 x .0022 x 1 = 0.00000152 cubic metres, or 1.52 litres.
Similarly for 15mm, 0.7litres.
Worth checking my maths.
Thanks Ian - your formula confirms what someone else told me but the radius would be 0.0011 on a 22mm pipe.
0.0011 :roll:
Nonsense. That's 1.1 millimeters
22mm is the outside diameter, it's 0.9mm thick so the radius is 0.0101m
and for 15mm which is 0.7 for the rigid stuff (or 0.5 for the bendy one)
r = 0.0068
Hope you have the rad volumes - much more than the pipes!
For an UNVENTED CYLINDER? If you mean this, it will not be your decision. It's either the manufacturer if it is supplied in a package, or a G3 registered installer.
If you didn't mean it, you don't need to be accurate, just work it out roughly and then add say 50%, or more. You can't have a vessel that's too big. Bigger vessels are less stressed.
